Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
So lately I have been noticing that "oil burning" smell on deceleration, checked the plugs and found ash deposits on the front cylinder plug (grey) so with my inspection camera I found a Blue streak on the front cylinder wall .
Would upload a pic but it seems lately I cannot do so.
Note: I had a T-Max, Bike was running very hot and had a ping now and then. Went back to mt FPS and runs cooler and no more ping with the map V&H supplied. And yes I have done the auto tune.
Ok , thanks to all. I just got off the phone with a very reputable source in this industry and sponsor , I refuse to drop names. Blue streak as I suspected....not normal, will cause rings to not seat properly and cause the smell and oil consumption. It has been too hot from a improper tune as some have mentioned. Lesson learned. Again....thanks to all
so...your issue is caused by the tune on the FP3?
also, I gather you are still running your stock jugs so how have your rings not seated.
just curious..hope you get it sorted.
