Scored Cylinder
#31
compare auto engine pistons with HD pistons. Look at the length of piston skirts...
Not totally sure, but wouldn't a shorter piston skirt create issues other than piston slap when the gap between piston and cylinder is larger?
I seem to remember, some years back, a post that featured an HD piston that had flipped almost 90 degrees (not necessarily because of this issue)
The 2 big issues are rattle and ring seal. If they turn sideways they are really too loose..
#32
2ndgenmarine (10-19-2018)
#33
How ever, i do have an additional question. with my jugs going 10 over, should i be looking for an exact 3.885 top end seal kit? or does the standard 103 top end seal kit work? i cant remember if that head to jug seal has or will have an overhang due to the machining.
#34
#35
