Scored Cylinder
Scored Cylinder
So thats it right? Once that happens you spend over 1k for bigbore cylinders and pistons? And i say that from ignorance since im having a hard time finding stock 103 replacement cylinders.
As i gather it theres no saving a cylinder once its scarred by taking it 5 or 10 over as apparently increasing clearance increases the chance of piston slap. i initially thought i can clean it up and put in some bigger rings, but reading some on here that dosent seem like a thing thats done.
I appreciate anyone who can clear up my findings. this is only my second time going into a harley as im used to working on GM pushrod badasses.
i think takin the bore 10 over would clean it up, but my hesitation in that comes from what ive read.
Harley carries a .005 and .010 oversized piston,ring set for little over $200. No big deal . Both require a bore and crosslap hone for ring seat. Any oversize requires a bore for true round
Done correctly, you will never know the difference.
Actually, if a scar that does not catch a fingernail hit with a medium grit stone for crosshatch will be fine.
Standard pistons with a .010 oversized bore would sound like a just started diesel at 20 degrees Fahrenheit. Guess, to some, that may be cool but compression would be about half with that much piston rock.
3 choices:
1) If it's visual and not a real scratch, just a pass with a ball hone should be fine. Install new stock size rings on piston.
2) If you want to run your existing pistons, buy a used OE 88 or 96 cylinder (95 and 103 are same bore) and have it bored for your existing pistons.
3) Buy a set of .005" or .010" oversize pistons and have both cylinders bored.
This is easy to fix.
Trust a random machine shop, better than nothing i suppose
i guess 88 is the same thing as a 103 since it always gives me those results
"imported" is a professional way of saying china i guess
other that those likes, its "you must want a big bore kit" or used. I understand that i could go through drag specialties or my local HD (...fffuuuuuu) and just ask for stock replacements for 600-700 bucks. which is why i understand now why people just say to hell with it and big bore it. thanks for the help so far, as i see it, this little **** up is going to cost me more than i really hoped it would. i havent ventured down the path of oversized pistons yet, ill see to that possible later.
