Stage 4 on 103
I assume you actually mean a Stage 3 kit, as the Stage 4 kits all come with cylinders? If so, the instructions are quite clear:
"It is assumed cylinders are new or very low mileage. Measure cylinders per service manual and check piston fit following instructions in supplied piston kit instruction sheet. If proper fitment cannot be attained (out-of-round, tapered, etc.) for standard pistons supplied, new cylinders must be purchased."
It seems that you should have two sets of instructions, the main set which I quote above, plus a set with your pistons.
I see different stage 4's for the 103. Some dealers sell the stage 4 with and without jugs. The one I bought, the dealer provided the 58 mm TB, high flow injectors, the 58 mm intake, and a screamin eagle race tuner (orange) . Sold the kit for $2300. I bought it for a .45 handgun and $650 and have sold all the pieces I didn't need and recouped $950 back.
I did some research with zippers and fuel motor and they say the stock TB and injectors are good all the way up to 125 hp,, beyond that, you should add the bigger TB setup and high flow injectors. I have sold all the extra pieces already and this didn't come with the jugs. That is why I am asking this question. The pistons are stock diameter but higher compression. I kind of figured that I would have to hone out the cylinders and will check the ring gap after. \
Any other input is welcome. thanks
when does the crank bearing come into play in a build like this? at what point should one do the conversion?
when is timken conversion required on engine build?
