Notices
S&S TC3 Oil Pump - worth it?
Old 10-23-2018, 05:03 PM
roadmutt's Avatar
roadmutt
roadmutt is offline
One Of The Regulars
Default S&S TC3 Oil Pump - worth it?
Finally got into the cam chest of the '01 FXD (23,700 miles, stock stage 1) to inspect tensioners and check TIR. The tensioners were intact, lifters and oil pump looked good, a little scoring on the pinion shaft but nothing major. Runout is .004. Was thinking gear drive to do away with tensioners forever, but will now stay with chain. Since I need to open it up to check tensioners, there's no preference on hydraulic upgrade or Cyco shoes.
The only real issue is the engine tends to occasionally spit oil out the breathers, the breather pads were good and soaked when I took the top end apart. Externally vented.
All of which got me thinking about oil pump upgrades to improve scavenging.
Putting parts lists together, a cam plate upgrade (new Harley oil pump) with Andrews 21N cams comes in at about the same price as S&S 509 chain cam with Cyco shoes and TC3 oil pump (310-0640). Keeping the stock oil pump with the 509 drops the price $400. Not even thinking about bargain pumps off ebay.
So is the TC3 worth it in this case, or am I just as well off with the stock pump?
Old 10-23-2018, 06:32 PM
ridealive1911's Avatar
ridealive1911
ridealive1911 is offline
One Of The Regulars
When I went 88 to 98 I used did the upgraded cam plate, oil pump and hyd tensioners from HD. I run 8lbs at hot idle and 32lbs down the hwy.
Old 10-23-2018, 08:46 PM
robarosa's Avatar
robarosa
robarosa is offline
One Of The Regulars
My stock cam plate, relief spring and pump, with Cyco shoes, S&S 509 has low 30 psi. No oil / breather problem or anything I can think of. 'course I ride like a old man. How do you ride your FXD?
ridealive: Like the bike.
ridealive1911 (10-24-2018)
Old 10-24-2018, 12:17 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 1,026 Likes on 853 Posts
Don't waster your money. Stock pump is fine for a stock or even moderately built motor.. Think about it if you want to try a 117 or 124 ci kit.
Old 10-24-2018, 11:30 AM
LazySundays
LazySundays is offline
Senior Rider
Daytona/Drag Specialties high performance pump and Cyco shoes. Very cost effective and works very well.
Old 10-24-2018, 06:48 PM
roadmutt's Avatar
roadmutt
roadmutt is offline
One Of The Regulars
Thanks. Considered it, but reason I asked about the TC3 is it specifically is advertised as handling excessive runout. Four thou isn't awful, but not great and not going to get better with time. I've found nothing on how the Daytona pump handles runout. Might be OK.
Trying to keep this a reliable, fun bike for what it is. Cams and intake/exhaust are all she's getting.
Old 10-25-2018, 05:13 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
as long as your pump is in good shape,id use it.get some CYCO pads
Old 10-25-2018, 09:45 AM
roadmutt's Avatar
roadmutt
roadmutt is offline
One Of The Regulars
Yep, the plan is 509s and Cycos and miles. Thanks for the feedback.
rob: I ride it like the guy who has to fix it. 😎
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
