HD Stage 3 or 5 kit for stock 103
All in, about 2700 for the kit and install. Another grand for the pipe and PV.
Thats my plan anyway.
I'm sure it'll be... justed wanted to know if the 7 cubes is worth 3k+... Although Andrew and I have issues I still believe he is a very good tuner .. but I've heard his prices are getting up there... You shouldn't have to pay more than $400 for a tune.... Might want to look at CPM in Coram....
Regarding Rosa’s. My only problem is I gotta leave the bike there a few days, and it’s a pita getting there and back home by public transportation. Not a huge deal, just not convenient.
Well, I look at it this way. The 110 SE motor in my old low rider S was fantastic. This kit will give me essentially the same motor, so I’d be happy with it. I’m considering maybe using a different cam then the SE255 that comes with the kit, like an Andrews or Woods. Looking into that a bit as well.
Black Hills Custom Parts
Ken
Rockaway, NJ
973-983-0200
Jim Moroney's Cycles
George
New Windsor, NY
845-564-5400
Mchad (11-12-2018)
I know where Moroneys is. I had no idea they had a Dyno nor a good operator. With all this EPA hoopla, warranty voiding if you tune your bike, etc. I’m surprised HD allows dealers to non-compliant tune anything anymore. I’ll give him a call tomorrow. I’ll be sure to mention you recommended him.
Thanks.
Thanks.
I haven’t done this yet, prettty close though. Was looking, and saw this kit that uses the stock heads instead of the SE ported heads, but ups the compression to 10.2:1 which means I could get some Woods or Andrews cams, vs. the SE 585s that come with it. https://www.harley-davidson.com/stor...ck-highlighted
Going this kit with cams will end up costing pretty much the same as the full stage 4 kit, so I’m waffling a bit between the two.
I’ll be using fueling lifters on either kit, and the SE cam plate and high volume oil pump.
So, full stage 4, or stage 3 with better cams is where I’m at now.
I did get the FuelMoto E-series 2:1 pipe, a Ventilator AC, and a power vision with an auto tune pro kit last week, so that’s ready for what’s next...
Bafflingbs (12-14-2018)
This kit? Nothing else but the gaskets? Nice numbers!
