front piston not firing
Old 11-21-2018, 07:14 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,907 Likes on 3,015 Posts
I love it when someone posts, gets us answering, throwing out suggestions fighting amongst ourselves and never returns.
The following 2 users liked this post by RANGER73:
PWMORRIS (11-23-2018), Tired (11-22-2018)
Old 11-21-2018, 07:22 PM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
The management here invents these one post characters to up the post count.
In turn, this invites more advertisers, intern, this place charges more money.
I guess there might not be anything wrong with it..perhaps a little devious.
Old 11-22-2018, 07:05 AM
Tired's Avatar
Tired
Tired is offline
Received 4,423 Likes on 1,687 Posts
The 02s don't have a CPS. Did you mean CKS? Plug wire, plug, coil, and ECU/ignition module for spark. If EFI, injector or injector wiring. Carbed? Probably not fuel if running on the other cylinder. Next would be compression.. Remember, you need pressure, spark and fuel to fire a cylinder.
Crankshaft Position Sensor - 32798-00B
Applicable for 2002 Twin Cam. But what do I know.
Old 11-22-2018, 07:48 AM
jbarr1's Avatar
jbarr1
jbarr1 is online now
Harley identifies the cam sensor as a CPS and the crank sensor as a CKS. Max is accurate.
That said, I never knew that it was the piston that fired. I guess the front cylinder is not firing?
Old 11-22-2018, 09:19 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,230 Likes on 3,611 Posts
As mentioned the part is the CKS. Also another thing to note would be that if CKS had issues both cylinders would likely have issues. The safe method for firing cylinders on an HD is to fire the front if there is a doubt as to which cylinder on the compression stoke.. Firing front cylinder on rear cylinder timing would be the same as advancing the timing 45 degrees.
Old 11-22-2018, 09:27 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is online now
Received 29,251 Likes on 11,137 Posts
I hate it when pistons don’t fire.
Old 11-22-2018, 09:48 AM
Max Headflow
Originally Posted by RANGER73
No, I moved it at the coil end. The wire on the rear plug won't reach the front plug smart ***.
Sorry, Not trying to be a smart as but it sounds like the spark didn't follow the wire, it stayed with the same location on the coil.
Add:
Don't know what bike you have so don't know is the wires are different or not.
I assumed the that bike wasn't single fire.
Old 11-23-2018, 09:07 AM
bravo103's Avatar
bravo103
bravo103 is offline
Stage II
Thanks for all the info. I'll try switching the wires at the coil. Then switching the injectors. I'll post results
Old 11-23-2018, 10:42 AM
Max Headflow
On a tc you can't switch the wires at the coil unless you switch the primary wires. The coil is single fire (2 separate coils).
Old 11-23-2018, 10:47 AM
TriGeezer's Avatar
TriGeezer
Why all the talk about spark. I thought the initial post by the OP said he had spark. I’m confused.
Quick Reply: front piston not firing
