04 ultra build
04 ultra build
04 ultra classic with 20k on the clock. Parts are at the machine shop now getting 95” bore with a planned cp of 10-1. Here are my questions I need help or advice with.
What cylinder heads ears would be the best for this budget build? Newer twin cams bolt on with a valve job? Spend the money for clean up and valve job on the 04 heads?
I have a set of tw55 cams that I could throw in but my research has came up slim with reports from others using them.
i can probably get the compression up to 10.5 with a smaller gasket just need to check piston height. I like the idea of using my original heads and just have them re worked also. Any information on the tw55?
A better cam selection for that bike would be something as easy as an Andrews 37, set at 9.8-10.0, along with a set of cylinder heads.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I’m looking at the fueling cams now.
Wood 6H would be a great set up, with great delivery.
Many cams to choose from.
One thing that you should be VERY aware of, is the undisputed fact that the 2004 year cranks were extremely prone to sissoring, once you apply any power to them.
Have witnessed up to .064" pinion, .042" sprocket T.I.R.(that one was an absolute hot mess)
2007's were next on that list.
Scott
Scott
B
Been awhile since I posted. I picked up some heads that were done by veetwin in 2016 with pistons and cylinders set up for 10.5, got all the parts on the bench and checked cylinder bore and clearances. Hopefully this week I’ll have the gasket kit , compensator and still need to choose a set of cams. The goal is to have it completed for riding to Daytona in March.
