Chris Rivas rocket 554 cam
Old 11-30-2018, 02:35 PM
IdahoHacker's Avatar
IdahoHacker
IdahoHacker is offline
Received 2,953 Likes on 1,685 Posts
You'll use the mid range every time you ride. Top end, not as often.
Old 11-30-2018, 08:36 PM
rgsboogie's Avatar
rgsboogie
rgsboogie is offline
Any other work done? I got a 16 rgs and she needs a little nudge! Been thinking about the woods 555 or 777, torque curve is impressive on the rocket cam! Gonna look back at woods to compare,I already have a Bassani RR,love it!
Old 11-30-2018, 08:53 PM
IdahoHacker
As far as performance, an SE air cleaner, the Pro Pipe, the 574 Rocket Cam, and a dyno tune. That's plenty for me!
Old 04-24-2019, 09:22 AM
jsimpsonS8's Avatar
jsimpsonS8
jsimpsonS8 is offline
Stage II
Default Rocket 554
Originally Posted by johnwesley
Does anyone have any experience with the rocket 554 cam? I’m looking to use it in a 97bb with head work set at 9.8 compression. Bike is a 05 superglide
I've had mine in a my '05 Fatboy for a year now, noticed a jump in midrange power. Sounds good at idle. I will say though that I have a little top end noise that wasn't there prior to cam change, mainly when ambient air temp is above 70 degrees and the engine is up to temp...may just need slight pushrod adjust.
Old 01-30-2020, 08:31 PM
Dan Mann's Avatar
Dan Mann
Dan Mann is offline
Stage I
Looking to get chris Revis rocket cams for my 2017 street glide. Which would be the best for my bike?
Old 01-30-2020, 08:38 PM
johnwesley's Avatar
johnwesley
johnwesley is offline
Call up to just shop, good chance Chris will answer, he’ll walk you through what you need.
Old 01-30-2020, 08:41 PM
IdahoHacker
I put one in my '15 RGS and loved it! Unfortunately, I can't give you any advice on an M8.
Chris is in California, so he can't put any details on his web site. Like johnwesley said, give the shop a call. If Chris is there he'll be more than happy to walk you through your decision.
rdc401
Engine Mechanical Topics
15
07-01-2019 05:54 AM
c4yourself2
Milwaukee Eight (M8)
13
02-23-2019 12:50 PM
brawner11
11-13-2018 10:54 PM
rdc401
11-05-2018 08:55 PM
flashracer
17
06-30-2018 04:23 PM
Quick Reply: Chris Rivas rocket 554 cam
