S&S TC3 cam plate and oil pump
Got a 07 punched to 103 with 10.5 comp pistons mild ported polished heads woods tw 777 cams, was wondering if is it worth changing the stock cam plate and oil pump with the s&s tc3 plate and pump? bought the plate along with some andrews 57h cams and decided to keep the 777 cams instead so don't know if it will be worth taking it apart for just the plate and pump.
Pump not needed. Been running 07 EGC with close to 90000 miles on a stock pump. From about 15000 it.s been a 103 with good heads, 4 different cams till 79000, Last cam was 777. Currently a 107. Bike has had over 100 pulls on different dynos. The plate and pump are good items but you really don't gain anything unless the stuff you got is shot.
How many miles on the current stock pump, how many miles since it was inspected (going to guess that was when the 777s were installed,) and was the oil pressure relief spring changed?
What was/is your crank run-out?
Those are the biggest things, other then if you have noticed problems.
If everything was/is good, I would leave alone.
IMHO.
IMHO.
We carry S&S pump/plates and Fueling OE plates, and those are available for those that do want them, however, we use the OEM plates, and pumps constantly in even our large cube engines.
Nothing wrong with those.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
hollywoodultra
02-26-2012 04:14 PM
JohnCA58
08-24-2009 03:14 PM
