S&S 510 cams
S&St 510 g
They work well in my 2005 Electra Glide either a 0.30 head gasket Rinehart Bub 7 True Duals Screamin Eagle AC Power Camander 3 USB pulls nice even 2 up & packed I never got a dyno sheet it was a favor and works. Actually probably has more in it ? Taking it down this winter and doing a 95 with CR575's & a set of Heads by by Wes Brown Cycle Rama and a Dark horse Crank .... I am selling these 510g cams I also have another 95" kit aND a nice set of ported heads, Vance and Hines Pipes for sale.....
S&St 510 gI
I believe so. You have to remember that the Tq. Curve will stay very similar in any engine size and will increase proportionately as cubic inches increase. As the displacement increases the cams will act Milder with the 510s in my 88 most people can't even hear them or notice any difference in the idle quality. Head work really wakes these cams up. My suggestion is to pull the heads it only takes about an extra hour do a cleanup on the ports a good multi angle valve job and a bowl blend your only looking at about $300.00 to do the heads reassemble it with a 0.030 gasket and have a Good tune done. There is no other modification that will give a better return on your money than Port work and a compression bump. Head work alone will pay off Big Time no matter what else you do Every Engine I do starts with a crank True,Weld and Balance gear drive cams and oil pump upgrade Topped with a set of mildly prepped heads. And Usually a New Rear Tire LOL
I believe so....... Head work really wakes these cams up. My suggestion is to pull the heads it only takes about an extra hour do a cleanup on the ports a good multi angle valve job and a bowl blend your only looking at about $300.00 to do the heads reassemble it with a 0.030 gasket and have a Good tune done. There is no other modification that will give a better return on your money than Port work and a compression bump. Head work alone will pay off Big Time no matter what else you do....... LOL
what special tools will I need for a complete cam swap?
thanks
My 09 ultra classic was originally a 96" then the PO had her upgraded to a 103" w 510g cams...Now the more research I do it seems the 551g would have been a better choice. Not unhappy with the power as Im not a speed demon but not sure why they chose the 510's.
Anywhere an S&S .510 is used, a .570 will produce more, if the springs will accept that lift.
Either will thrive at 10.2 cr.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
