Stage 1 Breakout. 30t 70t pulley. Tw 222 or tw 555?
50 50 2 up riding. Love torque. 14 103 Breakout. V&H Big Radius with Heavy Breather. Power Vision. Can't decide between the Woods 222 or 555. If I had stock gearing I would go with 222, but since my ratio will be 13% lower, my torque should come in sooner and to me it would seem that the 555 may be better ...btw, I've read post after post on cams etc. Just nothing found with my scenario. Thx
Keep in mind stock compression
From what I've read and heard the se585 work well with higher compression. Not sure on the Andrew's 57. I'm really curious your thoughts on whether or not I'm thinking correctly about the 13% increase in torque and being able to take advantage of the higher rpm torque of the 555 over the 222? Fuel Moto has a bunch of dyno pulls on these two cams with my set up.
Without looking at the charts would the 222 fit my situation better taking into consideration my 30 70 pulley swap? Does the pulley swap have an impact on my choice between these 2 cams? Thx
