Lifters and Rods
what brand lifters are the FM parts? ive heard smith bros makes FM p/rods but don't know where their getting lifters from. S&S p/rods & lifters used here,never had a issue
Kingglide549 (01-27-2019)
When I installed my cams in the Ultra, I researched the very same subject. In the end, S&S standard lifters seemed to be the go to in the aftermarket world both by shops and the guy's that wrench on their own bikes. Some may have a different preference.
I am no help on the push rods, I re used the stock ones, because I had to fix a leaking rocker cover at the same time. If I were to do it again, I would use the S&S Quickies and adjust them accordingly
Fuel Moto uses Smith Bros adjustable pushrods. I haven't heard anything bad about them, but they can be a bit fiddly to install and adjust. You may want to look at the installation instructions. I haven't used them myself, but I've herd some complaints.
I use S&S lifters and S/E adjustable pushrods. No problems. I'm sure the S&S quickie adjustables will work fine.
