95" big bore to100" s&s
greetings, this one is open to 1 and all. I have a 02 e-glide that has a 88" that has a se95" in it. The bike runs good but you know how it goes,,,what can we do to get it to go a little better,,so. If I was to put an s&s 100" kit in this, not sure what cams yet, it is has a s&s super e carb,,what do i have to do to get a 100 hp out of it? my heads have been worked on ,but don't know to what extent. I have a rinehart 2into 1 pipe, Any and all comments will help. Thanks, Butcher
mattbastard, thank u for the information. no,,i am not in a big cubic inch contest. i just want the motor to live and i don't know how far to push the 95". it has s&s 510 gear drive cams now, i talked with the tuner yesterday, and he is going to put something together. we'll see what happens.
I was in your situation, had Harley do the 95 upgrade but wanted more after a while.
Went with a 106 stroker built by Eric Bennett at Bennett Performance.
article about his shop and the process.
https://www.hotbikeweb.com/bennetts-...son-horsepower
springerboy (02-08-2019)
I had 105 hp out of my 95" years ago, with 10.5:1 wiseco pistons and 211 cams with a 2:1 thunderheader, so not sure why you would be struggling to reach that mark other than maybe that 510 cam being too timid. Is the 100" kit a bolt on or do you have to split the cases? If you split the cases its not worth it and go a different route.
100" S&S is bolt on, but it's the absolute MAX you can get and even then the cylinder spigots are really thin. There's a LOT of 95" piston options for TC engines, and it leaves some room for error if you pop the motor for one reason or another.
To the OP: Bump your CR up to mid 10's, get your heads worked over and capable of .600" lift, get a nice cam with a lift up around .600" (S&S 585 for example) and an intake close in the mid to late 40's and you should have a nice street ripper with at least 100hp with a flat torque curve.
And make sure to rejet the Super E along with appropriate ignition changes as well (like max advance around 26-28 degrees until you can break the new motor in and work on tune later).
100" S&S is bolt on, but it's the absolute MAX you can get and even then the cylinder spigots are really thin. There's a LOT of 95" piston options for TC engines, and it leaves some room for error if you pop the motor for one reason or another. To the OP: Bump your CR up to mid 10's, get your heads worked over and capable of .600" lift, get a nice cam with a lift up around .600" (S&S 585 for example) and an intake close in the mid to late 40's and you should have a nice street ripper with at least 100hp with a flat torque curve. And make sure to rejet the Super E along with appropriate ignition changes as well (like max advance around 26-28 degrees until you can break the new motor in and work on tune later).
The following 2 users liked this post by djl:
duglaura&flhti (02-09-2019),
Mattbastard (02-08-2019)
WFO Larry has 40 over forged KB pistons for a good price compared to CP.. You can correct the compression to use a better cam and do some work to the heads.. I like 06 up heads and AVnV valves with a little work.. Cr set to 10.8. I'm sure others have their favorite combos. I just used the pistons and TW55 cam. It makes for a strong motor but it does pull a little better up top..
