s and s gear drive
Old 02-14-2019, 11:09 PM
donk_316's Avatar
donk_316
donk_316 is offline
Maybe call S&S if random Internet forum opinions you asked for isn't what you want to hear.
Old 02-14-2019, 11:25 PM
blue06flhri's Avatar
blue06flhri
blue06flhri is offline
I never asked if i should run them the way they are. I asked if anyone knew how many thousands undersize that the undersize gears are.
Old 02-15-2019, 04:36 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
now theres a idea
Old 02-15-2019, 09:00 AM
djl's Avatar
djl
djl is offline
Received 2,029 Likes on 1,498 Posts
Originally Posted by blue06flhri
No im not an engineer but if S and S says that is the tolerances that it should be thats what I want.
Not likely to achieve S&S tolerances with .002" runout. Ran off the shelf S&S (Andrews grinds them BTW) at .0025" runout and had little whine which was barely audible. Even when runout grew to .0045", no issues, just a little more whine.
Old 02-15-2019, 04:55 PM
blue06flhri
Ok I have an undersize on order anyway and if its no better then what I got Ill just say **** it and run the original gear.
Old 02-19-2019, 04:16 PM
blue06flhri
Just an update. Got the undersize gear and lash is perfect at .0005 all the way around
Old 03-12-2019, 03:11 PM
crazytown's Avatar
crazytown
crazytown is offline
Yeah!!
Old 03-14-2019, 06:14 AM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,408 Likes on 864 Posts
Wait a minute... Unless I'm reading your first post incorrectly, it sounds like your concerned the .0005" clearance at 12 and 6 is too tight so you ordered an undersized gear. Now you've got .0005" all the way around (meaning the backlash got tighter), and you're saying it's perfect?
Back when I did a gear drive TC I had between .001 and .002" backlash on the big gear at 12, 9, 6, and 3, which I thought was perfect.
Old 03-15-2019, 09:49 PM
blue06flhri
No the clearance at 12 and 6 is right it was the no clearance at 3 and 9 I wanted to make right. For some odd reason when I put the undersize gear on it was .0005 all the way around. Call is .0005 to ,001. well within spec. I didnt make the gear all I know is its what I needed and is what worked for me
Superglide805
05-22-2013 06:41 PM
txtec
Exhaust System Topics
12-28-2008 03:04 PM
DeJavu
08-13-2007 10:14 AM
Littleshack
20
06-22-2007 02:09 AM
Quick Reply: s and s gear drive
