Mackie cams
Old 03-13-2019, 08:50 PM
Bruce Simioni's Avatar
Bruce Simioni
Bruce Simioni is offline
Stage I
Default Mackie cams
Hello, I see and have heard a lot of talk about how bad Harley lifters are.
Two years ago I bought a 2014 CVO ultra, from a dealer with only 5,900
miles on it . And went ahead and got a two-year extended warranty and that was a good thing. Just took it in with engine noise turns out it was a bad
lifter that also took out cam. But it turns out that the original owner had
Put cams in it. They were Dave Mackie cams that only made it 20,00 miles.
So Harley isn't the only ones who sell shity parts.
Old 03-13-2019, 09:05 PM
kel03's Avatar
kel03
kel03 is offline
Received 6,044 Likes on 4,356 Posts
Welcome to the new members area from Ontario, Canada. You may want to post that in the Mech/Tech area good luck
Old 03-13-2019, 09:16 PM
jblack902's Avatar
jblack902
jblack902 is offline
Received 1,118 Likes on 1,111 Posts
Welcome from Minnesota
Old 03-13-2019, 09:52 PM
Screamin beagle's Avatar
Screamin beagle
Screamin beagle is offline
Received 3,991 Likes on 1,997 Posts
Probably not the cams fault. You said yourself harley lifters are crap...chances are the guy cheaped out and didn't put in some after market lifters. Sad part is guess what brand of lifter your dealers going to "fix" your bike with? As soon as your warranty runs out put in some s and s lifters with some koyo inner cam bearings the next day and enjoy the ride.
Old 03-13-2019, 10:08 PM
sloufoot's Avatar
sloufoot
sloufoot is offline
Moderator
Received 4,081 Likes on 3,483 Posts
Old 03-14-2019, 03:42 AM
critter85's Avatar
critter85
critter85 is offline
Received 2,497 Likes on 2,475 Posts
Welcome to the Forum
Old 03-14-2019, 07:04 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
The root issue with lifters taking a screaming dump in a CVO 110", are the extreme duty triple valve springs, that HD sourced from Comp Cams.
Once those are attended to, a good quality lifter will live.
The HD "C" lifters, manufactured in Mexico have something to be desired, thus the reason we use S&S lifters here.
The David Mackie cams are good cams, that produce good power.
None of this is opinion, as a quick Google search will reveal the widely known facts.
Ain't the cams fault....
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 03-14-2019, 09:03 AM
PDB17UltraRG's Avatar
PDB17UltraRG
PDB17UltraRG is offline
Welcome to the site lots of great info here enjoy from Stuart Fl. Ride Safe Ride A lot
Old 03-14-2019, 09:27 AM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
This is not the cams fault. What lifters were used in conjunction with the Mackie cams? Also, those 110's have stupid heavy valve springs that don't do any justice on your valvetrain...
Old 03-14-2019, 10:13 AM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
I hope it is understood that Dave isn't grinding his own cams and my guess is they are being ground by one of the companies that grind a lot of different cams in this industry.
markp1965
Engine Mechanical Topics
07-28-2014 07:06 AM
DXHD $100
07-08-2013 08:26 AM
Plaidfinger
08-04-2012 07:50 AM
zippo2
05-10-2012 02:54 PM
CSMHOG
06-07-2010 04:29 AM
Quick Reply: Mackie cams
