Head Gasket- 2007 Twin Cam A
What head gasket do you prefer to use, meaning manufacturer and material of gasket? Also does anyone know the thickness of a OE head gasket for the 2007 twin cam? James has a .036" and a .045" "with armor" gasket, and a MLS type gasket but they don't list the thickness of it... I tried calling Harley and they didn't know the thickness of the OE gasket, which is hard for me to believe, but that's a whole different conversation.. Thanks for any help!
Thanks for the info,,, IYO with the motor being completely stock do you think I would be safe using a .040" gasket, as far at PTV clearance goes? not trying to change compression either... Also to play it safe, and say I just clay the piston, should I buy an extra gasket just for the test? and then install another new one for the real assembly...
I have mocked up and reused MLS head gaskets several times with no issues.
dyna50 (03-19-2019)
Actually, you would be fine with a .030" and would benefit from a small compression boost; no worries about PTV clearance. IMHO, you are not changing cams, pistons or valves and only reducing the distance from valve to piston by .015" so I doubt that PTV clearance is an issue. Actually that distance is a little less because the pistons are probably below the deck by .003"-.005". Of course, claying the pistons is best, always better to measure; no guessing. Consider mocking up and claying using the OEM head gasket (measure the compressed thickness first) Then subtract the difference in head gasket thickness from the thickness of the compressed clay and you will know how much PTV clearance you have; I think you will be surprised how much there is. Allow .040"-.060" clear. You can also check deck height in the process. This way, you can order either the .030" or the .040" as required but I am sure the .030" will work. One way to do it quickly would be to refrigerate the clay so you can cut a pad 1/8" thick that will cover the intake valve relief. Put the head on, sans gasket, and slowly rotate the piston through TDC. Remove the clay and, if it has been compressed, measure and to the math.
