Cheaper build? Only the third time asked I'm sure...
Looking for a budget build, I think I read somewhere the the jugs from a 96in will fit the 88 tc? Can't remember.. Or would it be better just to have headwork done? I can get jugs and pistons cheap... So I'm not sure which one would be best for me?
Just want a little more umph..
Already cam'ed and geared the bike.
Thanks
Thanks
Thanks
Thanks
Budget build....bore your 88 jugs to 98" and get a cam to match or use your cam and make sure it'll work with the increased displacement.
Bore to 98".
Andrews 37 at 9.8-10.0 cr.
That will cover a long list of bikes/riding styles.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
The OP did not mention fuel management or exhaust and funds may not be available for boring, porting, fuel management and exhaust so the upgrades might have to be done in phases. If the OP is not currently running a fuel management system and the current motor has not been dyno tuned, he should consider finding a tuner that will sell him a Power Vision license and have the motor dyno tuned as a Phase I upgrade. Phase II would be boring to 98"; clean up heads, new guide seals, maybe new springs, SERDI valve job, (set up so compression works with current cam set); .030" head gasket and retune. Include head porting in Phase II if funds are available; if funds are not available, include head porting and exhaust upgrade (depends on what OP is currently running), retune in Phase III. Of course it would be better if the OP could wait until the funds were available to do everything at one time. JMHO.
If you have "a few grand" a 98" top end and ported heads are well within reach. SS exhaust is not the best performer but if you are not chasing every bit of TQ/HP, they aren't the worst. The 37 cam with the right compression and maybe a set of 1.7 ratio rockers will make some decent numbers if set up right. A programmable ignition would also be a good addition to the package.
