Cam Chain Tensioners...99-06 only?
I have heard about the issues on here with the Cam Chain tensioners wearing and so on.
my question was most all I have seen was for 99-06
my bike is a 07 Heritage is this something I need to look into also? if so anyone have a good read somewhere on how to check or possibly replace if needed? **** has about 18k on the clock
'07 and up models came with the later hydraulic tensioners and roller chains. Tensioner pads are still consumable pieces of hardware but not subject to instant catastrophic failure like the early Delron pads. At 18K miles, no need to check IMHO unless you are just curious. Check at 30K-35K miles and, if you think replacement is necessary, replace with a set of CYCO pads.
Campy Roadie (05-09-2019)
Campy Roadie (05-10-2019)
That's how often I check the tensioners on mine. ('01 Dyna)
I keep telling guys that they are a mainenance item and need to be checked, but they keep crying that they should last forever and that they are not in fact a regular maintenance item because they couldn't find it in the owners manual.
Depends on the chain burrs.
Some crapped out earlier than others but the average is the 25-30K mark initially.
Cyco shoes.
Scott
Cyco shoes.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
