Blew oil cap off and now it won’t idle
"So I replaced the air filter and ran around the block with it and it’s blowing oil out of the breather pretty extensively and the noise coming from the vent on the breather is way louder than before. When sitting at idle or when riding you can hear the vented air coming through the vent hole (no, it’s not the sucking sound from the carb pulling air)."
If you didn't assemble the breathers wrong, there is likely something wrong with the scavenge pump. These bikes need tensioners replaced every 20 to 40K It's worth while to check cylinder leakdown.
How many miles on the motor?
Well it has about 5000 miles on a complete top end rebuild, new valves and seats, the head was re-done at about 2000 miles due to the builder over tightening a push rod and bending a valve and retainer. When the head was re-done he looked into the cam chest and everything to make sure everything was good, and didn’t see anything and checked the cam shoes and what not.
So I rented a compression tester from Autozone and of course it didn’t work because it was the wrong size. But when I pulled the rear plug it was black and had oil on it. Pulled the head and found oil pooled up on the exhaust valve relief on the rear cylinder. Yeah, I know I should have probably checked compression before doing this.
3-4K miles after a complete top end rebuild, I’ll never pay to have someone do work on my bikes again. I’d rather mess up and damage my own stuff, rather than pay $1600 and have it blow up a year later. Oh, and the builder over tightened a pushrod and bent a valve that I had replaced by a different shop.
