Rocker box gasket leak 103
Howdy,
The dealership service pointed out a small seep of oil from both rockerbox covers (fore and aft). Replacing the gaskets looks pretty straightforward (pull tank, remove covers, clean and replace gasket, install covers, install tank.
It doesn’t look like the $500 job they quoted. Am I missing something?
Should I do anything else while I’m in there?
2013 FLSTC 44,000 miles. 103B
Thank you
Thank you
Howdy,
Thank you
Thank you
I think I would try raising the tank an re-torquing the rocker box bolts first since the gaskets are "seeping" and not leaking. JMHO.
skullcrusher
03-05-2009 07:30 PM
