Crankcase ventalation
Old Aug 25, 2019 | 04:06 PM
junkyardscrounger's Avatar
junkyardscrounger
Default Crankcase ventalation
Noticed a little oil in the air filter on my 07 FXD so is there a pcv valve on these engines.
Old Aug 26, 2019 | 08:23 AM
bustert's Avatar
bustert
in both heads, the is what is called an umbrella valve, a rubber one way disk assy. these can go bad and cause such things. hd vents to the air cleaner. if you have a high mileage machine, blowby can over-whelm the system or other things can cause issue such a sustained high rpm as the oil will have a tendency to pool. above 5k, the c/c with transition from a negative to a positive pressure, hd uses diff'l pressures to move oil around.
Cooper08
Touring Parts
Sep 16, 2009 08:31 PM
NoLongerAmember
Aug 29, 2009 10:22 PM
harleyrunner
Carburetor Related
May 29, 2009 07:44 PM
roadkingwinner
Aug 24, 2008 02:44 PM
rbcss
Jul 12, 2007 01:13 PM
