2008 night train engine
Old Nov 11, 2019 | 09:56 PM
Silent_Sapper's Avatar
Silent_Sapper
Default 2008 night train engine
So I am looking at buying an 08 night train with motor work. The current owner doesn’t know all of what was put in it in 2013 he had a big bore SE put in by dealership. The current owner states he told them to make it as fast as possible, I called the dealership that did the work only has it down as “ big bore install”.. I know it’s had work done as the heads have release valves installed on them. She moves pretty well but I like to know all of what’s done. There are no markings like 110” or anything. Anyone know if this would be a 103 or 110?
Old Nov 12, 2019 | 05:21 AM
ntraindavefl's Avatar
ntraindavefl
Work done in 2013 would imply a 96 to 103 upgrade
Old Nov 12, 2019 | 05:55 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
If cases were bored, it could be a 110", and that could be the "maximum effort" that dealer did.
Only way to readily, easily, verify would be to pull a head, and measure both bore and stroke.
Scott
Old Nov 12, 2019 | 10:22 PM
Silent_Sapper
Thanks for the info,he is trying to get the papers from when the work was done since Stealership is no help. Would it be better if the engine was 103 vs 110, since i have heard many issues with the 110?
Old Nov 13, 2019 | 06:01 AM
Hillsidecycle.com
Sponsor
CVO 110" yes, 110" drop-on kits of the use of only 110" cylinders, no.
Scott
dortiz
Jul 4, 2011 07:09 AM
FLSTF
Exhaust System Topics
13
Nov 12, 2008 10:20 AM
DRCLB
Screamin Eagle CVO Models
Mar 29, 2008 06:42 AM
augiedog
Mar 3, 2008 01:29 PM
