Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
The drive belt lasts a long time unless you pick up a rock or some debris. Mine has 67,500 miles on it and going strong. Will trade the bike before having to replace the belt due to wear.
The belt drives the rear wheel. You can see it from the left side of the bike. The primary will have to come off to replace it.
As stated above, unless there is physical damage to the belt or pulleys, the belt will last up to and sometimes longer than 100,000 miles.
How many miles are on the bike now?
I suggest you get a Factory Service Manual and learn about your bike.
