Heads
Old Aug 10, 2021 | 07:20 PM
maverickfe's Avatar
maverickfe
Default Heads
I have a 2000 Fatboy I read that I can put 2006 Heads on mine so would this be true?
Old Aug 10, 2021 | 09:36 PM
Max Headflow's Avatar
Max Headflow
The will bolt right on but you'll have to change the intake manifold rings to the 06 up version.
Old Aug 11, 2021 | 08:19 AM
prodrag1320's Avatar
prodrag1320
Yes,they will fit.as said you just need the late flanges.they are a very nice upgrade but will still benefit with even mild porting
Old Aug 11, 2021 | 07:27 PM
maverickfe's Avatar
maverickfe
Thanks so i need to get 2006 and up manifold flanges then?
Old Aug 11, 2021 | 07:46 PM
Max Headflow
Yes. That's all, other than the usual gaskets, and the heads will fit. The manifold rubbers are the same.
Old Aug 20, 2021 | 05:13 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
With that enlarged exhaust port, you should notice it running a bit cooler also.
Scott
Old Oct 17, 2021 | 02:19 PM
maverickfe's Avatar
maverickfe
thanks for the help
skydude426
Engine Mechanical Topics
Feb 20, 2015 07:09 AM
58Panhead
Oct 19, 2011 04:10 PM
Hawghauler
Exhaust System Topics
Sep 23, 2011 03:47 PM
riden2low
Apr 27, 2011 12:47 PM
tiiiim2
Jan 20, 2007 10:14 PM
