Runout process
Old Nov 28, 2023 | 06:12 AM
M Oclaf's Avatar
M Oclaf
Originally Posted by djl
Whaaaaat are you talking about?
curious about methods that folks use for working on their bikes. It’s an HD forum.
in this instance, crank runout.
Old Nov 28, 2023 | 06:55 AM
Rusty Springs's Avatar
Rusty Springs
I bought the tool from Fueling. It’s a decent tool but a clamp on dial indicator is more versatile.
Old Nov 28, 2023 | 07:50 AM
user 7209823083's Avatar
user 7209823083
Some sources say you must measure run out without the cam plate in place, others say the opposite. Which is true, or does it even make a difference?
Old Nov 28, 2023 | 08:17 AM
djl's Avatar
djl
Originally Posted by M Oclaf
curious about methods that folks use for working on their bikes. It’s an HD forum. In this instance, crank runout.
Since I have been on this forum for 17 years, I am well aware that "it's an HD forum". I showed you several ways to measure crank runout and your reply to that post does not make any sense. I think a reply like "thanks for taking the time to post photos, blah, blah.............would have been a more appropriate reply. Anyway, I hope you got your questions anwered.
Old Nov 30, 2023 | 10:53 AM
Max Headflow's Avatar
Max Headflow
Without. The cam plate can constrain the runout..
Old Nov 30, 2023 | 12:17 PM
jake24lt's Avatar
jake24lt
Why would you need the cam plate in place? Secondly, if you leave the plate on, how are you going to access the shaft? It barley protrudes out of the plate.
Old Dec 3, 2023 | 06:49 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Always check run out on opinion shaft when replacing cams. There shouldn't be any question as to whether or not the cam plate should be on or off... You're taking it off to do the cams..
Morrid7
Twin Cam Motors
11
Feb 7, 2022 12:20 PM
Mars47
May 24, 2015 11:19 AM
woodeyewetzel
Mar 31, 2009 08:23 AM
Sleeps In Trees
Exhaust System Topics
11
Mar 2, 2008 03:19 AM
dxrich
Jun 9, 2007 08:40 PM
