Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm adding ACR's on an 2011 FLHTC. I have the harness 70623-08. I was able to install the ground wire to the ECM connector at pin #19 per the instructions. Not a problem. Connecting power wires at the fuse block is a different story. I was able to remove the fuse block from the caddy and remove secondary lock but could not seem to get the terminal wire from the fuse block. Was afraid I was about break something. So I just reassembled the fuse block and caddy.
My question is, it looks to me that the ACR's just need switched +12v power at one side at ACR and ground is controlled through the ECM at pin #19.
So would it be possible to power ACR's with an "add a fuse" plug in and just cconnect wire from that to harness. That way I don't have to reconfigure the fuse block. Ground wire remains at ECM connector. Add a fuse will plug in the ignition fuse slot
Well, gave it another try. Finally figured out how the terminals locked and unlocked. A little tiny flat screw driver. Now wired per the harness instructions.
A few YouTube videos had sent me down the wrong path with the terminals and tools required.
