Fixing Stripped Out Drain Plugs
Old 01-11-2006, 10:53 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Fixing Stripped Out Drain Plugs
Submitted by: springer_ (V Twin Forum) & http://www.bigboyzcycles.com/
There have been several posts lately about stripped out drain plugs in EVO oil pans. Today I had the opportunity to deal with this exact problem. Of course I took pictures and documented the whole fix, including some custom modifications.
I went to a local auto parts store and looked through their fix it section. I found 3 items that could work and not knowing which one would work better, I bought all 3.
On the left is a 1/2"-20 Double oversize plug
Middle is a 1/2"-20 "Piggyback Single Oversized" Plug
On the right is a 1/2"-20 Single oversized solid tapered plug
This is the Piggyback plug that we decided to use since it allows the oil to be drained without a pump. You can see the o-ring on the new drain plug. Note that there is no relief in the "seat" for the o-ring. This clearly isn't going to work.
We removed the o-ring and found that a 10mm banjo brake washer with a rubber lining fit very well. Here you can see it and the stock o-ring.
Left Side, we installed the o-ring and as soon as you tried to tighten the drain plug it just squished out. This certainly would have leaked and probably would have vibrated out. For the o-ring to work it would need a recessed step that would allow the o-ring to seal the drain plug but allow the head to seat firmly, holding the plug in place.
Right Side, you can see the Brake washer in place. It allows the drain plug head to seat tightly on the washer. The rubber lining then gets crushed between the 2 surfaces on the inside of the washer thus sealing it.
Additionally we used the solid tapered single oversized plug to start the rethreading of the oil pan. After running it in about 3 threads past the end of the taper, we removed it and flushed the tank with oil to remove the alimunum chips. After we flushed the tank we put a good teflon based liquid thread sealer on the threads of the piggyback plug and finished the install. This allowed the final plug to cut its own threads as it was installed and firmly seat itself.
Comments:
We had considered using grease to help collect the aluminum chips, but then you have to use a solvent of some sort to get the grease and chips out, like kerosene. After looking at the self taping plugs we decided that it was not going to produce aluminum chips like a regular tap would. So we decided to tap it dry. It produced more of an aluminum dust that mostly stayed in the threads of the plug. We then flushed it with oil just to have a flow over the new the threads. This washed out any of the dust left in the threads. If we had taped it for a helicoil it would have been a different story. We looked at using a heli coil first but there wasn't enough room to drill and tap it while still mounted in the bike.
Old 06-01-2010, 07:16 AM
bikefxds's Avatar
bikefxds
bikefxds is offline
I did the same thing and bought the NAPA plug you used. It is the third one of the three you have listed(the 1/2"-20 Single oversized solid tapered plug). Do I need to drill a hole in the center and put in a small magnet to make this a magnatized plug, or can I just use it as it is forever? Thanks
Old 06-02-2010, 07:58 PM
0734's Avatar
0734
0734 is offline
Tech......you go after things like I do. Most of my friends accuse me of trying to over-fix anything I do....and I admit it's a good idea to install a plug in that aluminum pan with ....well...another plug in the end of it so you are removing and tightening steel-against-steel. To use an o-ring...you would need what is called an ORB (o-ring boss) fitting. The ORB has the grove cut for the o-ring and it won't squeeze out.
Bike....MOST of them are fixed with the one oversize plug you used along with a fiber washer. If not having that magnet in there troubles you...you can get a magnetic sleeve to slide over your filter, or do what I do...I have a big magnet that I simply "stick" on the end of my filter. I have cut open many filters and can see the "gathering" of metallic stuff on the inner case of the filter where the magnet sticks.
I do not use my drain plug...ever. I use that hole for the oil return from my cooler and all I have to do is loosen the AN-6 fitting on the cooler thermostat at the front of the bike. Just take the fitting apart and stick the hose in a container. I have a 1/2 x 20 ORB to AN-6 adapter in my drain plug hole to attach my cooler return hose and I never have to remove my oil drain plug.
Old 10-20-2010, 10:07 AM
rsmit22's Avatar
rsmit22
rsmit22 is offline
Stage IV
I have installed the same oversize piggyback tras drain on my 07 softail. The problem I now have is that the piggyback plug is a 9/16 head and I cannot get this size socket square on plug head because of shock .I have tried to find an allen head bolt to use but have discovered this piggyback plug is 23/64ths. Any help would be appreciated.
Old 10-20-2010, 10:38 AM
im's Avatar
im
im is offline
would a crows foot work ?
see link for crows foot
http://www.harborfreight.com/7-piece...set-94426.html
Old 10-20-2010, 10:46 AM
rsmit22's Avatar
rsmit22
rsmit22 is offline
Stage IV
I will try the crows foot. I also am cosidering cutting the head of allen bolt and welding to the piggyback! Thanks
Old 10-20-2010, 11:06 AM
im's Avatar
im
im is offline
Another option for consideration is to take a second look at the hole for the drain plug...
Some models have a huge amount of internal threaded area.
May consider a longer pilot point type drain plug/bolt and dremel a space for an o-ring on bolt or just use a large rubber gasket..but that set-up might bring you back to the same clearance issues..but would look more factory..If you sell the bike.
Welding the allen to the bolt would be quick but might cause some clearance issues with shock and might not look pretty..but i do not know how to weld.
Tailpipe
Oil Archive (no new posts)
04-13-2020 10:51 AM
ckamin
05-25-2019 07:16 PM
Torpedo1
01-29-2019 10:30 PM
bigirn
Exhaust System Topics
13
04-07-2013 10:09 AM
darylnj
EVO
01-04-2013 07:07 PM
Quick Reply: Fixing Stripped Out Drain Plugs
