cam change
Old Mar 27, 2014 | 11:33 AM
truckinpete's Avatar
truckinpete
6th Gear
Default cam change
motor is is apart for upgrade 88 to 95 se cast ft pistons, minor work on heads valve job, seals, possible mill for compression. motor is 2006 i have camplate and oil pump from 2010 so cam choice andrews 26 or 48 or other for use with newer camplate .low compression build so choices for this only.
Old Mar 27, 2014 | 12:12 PM
djl's Avatar
djl
S&s 509?
Old Mar 27, 2014 | 03:29 PM
nhrider1's Avatar
nhrider1
Originally Posted by djl
S&s 509?
Don't think S&S does conversion cams. They are needed with the 2010 cam plate.
Old Mar 27, 2014 | 04:26 PM
djl's Avatar
djl
You are right about the conversion cams; none from S&S. I am an Andrews and TMan guy and just recently started looking at S&S cams for 98" build in the works and not as familiar with their offerings; my bad. However if truckinpete happens to be riding a Dyna, no worries. Oooops, wrong again, no 509s for later models but he could run the 551s or 583s if bike is a Dyna. If not a Dyna the OP is back to the Andrews 26 or 48 both of which are available as a conversion cam. In which case, the 48 would be my pick.
Old Mar 27, 2014 | 04:46 PM
truckinpete
6th Gear
thanks for the reply. this bike is a heritage solo rider country road daytripper.
Old Mar 27, 2014 | 08:21 PM
djl's Avatar
djl
Andrews 48 over the 26 every time. You didn't say what year; if prior to '05, valve lift will be an issue unless addressed with head work.
cycler
Engine Mechanical Topics
Sep 22, 2018 12:18 AM
pehenley
Dyna Parts
Jul 29, 2018 06:28 PM
STLBagger
Apr 20, 2016 05:00 PM
SeaHag
Exhaust System Topics
Aug 14, 2008 01:51 AM
Clifton63
Nov 29, 2007 06:46 PM
