Minimum cylinder pressure
99 EVO engine, at least 48K miles - giving me hell not starting when it is cold. Only hits on front cylinder. Done all of the ignition checks (plugs, wires, swaps, etc), all AOK. Checked rear cylinder pressure - 88 pounds - did the oil-add - same. No, haven't checked front, have to remove tank to get tester in place. Am I at the point of needing heads done? Dumb question - can heads be removed without pulling engine? Thanks.
Received 4,317 Likes
I wouldn't stop at the heads though I would take off the jugs too so that you can inspect them and the pistons as well.
All of this can be done with the motor in the frame.
cyl. comp. test.
Your description of " did the oil add - same " dosent compute ?
Correct procedure for cylinder compression test is ... run motor to operating temp., ensure you have a fully charged battery , remove both spark plugs , ground out both spark plug wires or disable coils , install cylinder pres. gauge into spark plug hole , open choke , open throttle completely and hold open , rotate engine for 10 seconds and observe the gauge. Comp. should rise evenly to a maximum reading and stabilize there.
Record the reading and do same for other cylinder.
Next ... add an ounce of motor oil into the cyl. to be checked a second time , wait 5 min. for the oil to migrate , do same procedure as above and record the readings for each cylinder.
Last ... You should show approx. 90 lbs. for each cyl. in the first check.
You should show a higher pres. for each cyl. after the oil added step.
What is important is the difference in readings between both cylinders.
If you see a difference of more than 10-15 lbs. between both cylinders you have a rebuild in your future.
Be advised that a compression test is a start point only. Other inexpensive test procedures are available to specify a particular area of possible problems like valves etc.
How are you doing your cyl. comp. test ? No reason to remove tank.
I haven't checked it after the rebuild but I'm sure it is higher now.
