Has anyone seen this before
So I recently took a '95 Electra Glide FLHT in trade and as I was changing the grips I noticed this on the clutch side. It looks like a air stem that the chrome end of the grip screwed into to hold the grip on. Pressing on the stem no air releases. At first I thought the previous owner had routed the rear air shocks up to this to fill/ release air from the shocks. I doubt this stock. Having this stem there though does not allow me to put on new grips. Before removing it I wanted to double check with the guru's here to make sure I am not wrecking something.
Thanks for the help all!
Mid 90's have air fork suspension. I suspect you are looking at the schrader valve for the front "air forks".
FROM MY FSM:
Rider weight up to 150 lbs 0 lb psi
each additional 25 lbs add 1 ib psi
Luggage weight for each additional 10 lbs add 1 psi
MAX 25 PSI
get a suspension pump and filler up!
FROM MY FSM:
MAX 25 PSI
FROM MY FSM:
MAX 25 PSI
FROM MY FSM:
MAX 25 PSI
For parts info there are on-line websites like this one worth looking at.
I buy most of my parts from J&P Cycles. If you plan on buying a lot of parts it is good to purchase the gold club. They have always been great to deal with. http://www.jpcycles.com/?utm_source=...FUyVfgodXQUPsg
