1996 EVO EFI stumbling in the heat???
Wifey's EVO EFI has just started when it's hot. It will cut 3-4 times for about a second then run fine for a while. It runs perfectly when the weather is cool.
I wasn't sure about the heat correlation at first so I went over everything that might have been a problem. Found some corrosion on the fuel pump fuse. The bike ran fine for 3 hours this morning so I thought I had solved the problem. Then it started stumbling again when the temperature hit the high 80s.
I'm wondering if there is a problem with the head temperature sensor??
Any other ideas?
Thanks.
Joe
Any other ideas?
Thanks.
Joe
I've read here that some of the later ignition triggers (which detect the cam position-hence "cam sensor"?) have been known to melt from prolonged exposure to heat.
