Changing from 20w50 to Lucas Primary Oil??
1998 stock Fatboy, I've owned it for 6 years and have always used Mobil1 20w50 Synthetic in the primary. Saw "Lucas Primary Chaincase Oil" in the local auto parts store and wondering if I should switch. Are there any pros/cons to running one over the other?
Any input from the EVO gurus?
Received 4,317 Likes
I use synthetic ATF. I don't think it's cheaper, but it sure makes the clutch work smooth. I was using Mobil1 ATF, but the local auto parts store didn't have it last time I changed a primary oil (chopper), so I went with the Royal Purple ATF.
HD doesn't have the primary chain case oil like they used to. What they sell now doesn't work for me. Makes gear changes all clunky.
I ran type F ATF for quite a while in both my old Heritage and in the EG. It did just fine, never an issue. Now I run the HD primary and transmission oil. Never noticed that it mattered. Next change will be back to ATF.
