Position of Clutch Rod Bearing 1987-89 Evo
Old 04-27-2016, 04:03 PM
R@GZ's Avatar
R@GZ
R@GZ is offline
3rd Gear
Default Position of Clutch Rod Bearing 1987-89 Evo
Do any of you guys have a drawing of the assembly for a 1987-89 evo right side clutch rod end assembly that is clear enough to see which way the (Bearing-Push Rod) Part no. 37312-75 , installs on the shaft? It has a front and back side and rides between the thrust washers.
If anyone has a drawing or remembers this I sure would appreciate the info.
Someone must have gone nuts on the clutch adjustment and got this stuff really hot.. hell fire the thrust washers were welded together and i found what was left of the shell of the push rod bearing in the bottom of the derby cover.
Thanks Dudes..
R@GS
Old 04-27-2016, 08:02 PM
GraemeR's Avatar
GraemeR
GraemeR is offline
Its normal for the bearing to give up the ghost and for the actual rollers to 'disappear'. Later years modified the setup to include an oil thrower thingy that at least delivered oil to the thrust bearing so that they last longer.
sparky0496 (07-08-2021)
Old 04-28-2016, 07:19 AM
R@gs's Avatar
R@gs
R@gs is offline
1st Gear
Thank You Sir. I looked all over Hells Half Acre and couldn't find the info until you posted it.
Chefgmac
02-21-2019 01:46 PM
persuader
EVO
05-17-2017 07:39 AM
SeaZund
EVO
03-05-2015 05:16 PM
DJ Baar
10-05-2011 10:49 AM
badcopnodonutttt
Shovelhead
04-15-2009 03:19 AM
Quick Reply: Position of Clutch Rod Bearing 1987-89 Evo
