97 Dyan shakes when slowing down
A couple of years ago, I realized I had developed the habit of taking my hands off the bars and doing a little stretch as I was coming up to a stop. It was entirely subconscious. Didn't know I was even doing it.
UNTIL I put new tires on the FXR. As soon as I did, it developed a bit of a shimmy in the front under the "no hands/rear brake" situation. No biggie, although the first time it happened it was a bit of a pucker. For all I knew it was about to flop into a tank slapper.
As the tire wore in, this went away, mostly.
I'd be willing to bet it's the rpm shake these dynas have. With a worn front mount it's very noticeable down shifting as the RPMs drop through the 2k range and the engine braking is putting extra strain on it.
Pulling in the clutch masks it because it drops past it instantly when pulled in.
My 94 did that until I replaced the engine mounts. Front was shot, rear was OK but replaced them both.
The rubber in the front mount can fail faster if motor oil gets on it (from an oil filter change). I guess the oil is not good for longevity of the rubber.
Do a search on the dyna motor mounts, hard to describe, but you can look to see if the center rubber square inside the mount has sagged and is touching the inside bottom edge of the mount. It should not be touching.
If you have to replace the mounts, follow the engine alignment procedure in the manual, and do yourself a favor and pick up two of these when aligning the engine:
http://www.harborfreight.com/dial-ga...der-34214.html
One for the front brake rotor and one for the rear. YD
Beagle1
09-17-2006 11:00 AM
