Check to make sure the leads on your multimeter are set up correctly for AC if you are checking at the stator plug. Most multimeters require the leads in a different spot than when checking DC/continuity/OHMS
Neither of mine do.
One has a button to switch between AC and DC and the other you have to set the dial selector to AC scale.
I've had a dozen multimeters, maybe more, counting work. I've never had one that had to have the leads moved for AC v. DC. Not saying there are none, just none of mine.
