90 fxrs carb backfire
my bike runs great..but when I'm out to the store and it sits for a few minutes
it will back fire thru the carb when I start it and unseat the carb causing a major vACUUM LEAK. I have to tear it all apart to reseat the gasket to the intake . I've already check for vacuum leaks while bike is hot , none found. Any suggestions?
Received 4,317 Likes
edjhover (05-24-2016)
It also sounds like something is not right with your gasket. I think your saying the carb to manifold seal becomes unseated when it backfires?
Replace that seal and check alignment of the carb. Is the carb mounted properly with no play, gaps, or movement to that seal at the carb to manifold?
I agree with the others, your slow/idle jet is lean. Pick up a couple of sizes larger than what you have. If your stock is 42, then get a 45 and or a 46 in there. YD
Received 14,138 Likes
