What year did Harley go to the 2.2 inch hub on their wheels...
Upgraded the wheels on my Low Rider for my build, now I need a 1 1/2 inch rear belt wheel pulley with a 2.2 diameter hub bore and I'm having trouble figuring out when they when to the 2.2 hub and if they have a 2.2 hub/1 1/2 inch belt pulley. Did they switch over in 2000? Or am I going to have to bore mine out?
Thanks and Have A Happy 4th!
With a later hub you also have the opportunity to change from the original wide belt to a later narrow one. I have a 1 1/8" belt on my 1990 Glide, with a Deuce rear wheel, a 2004 touring wheel before that. IIRC the narrow belt was introduced 2004, so for a 1 1/2" pulley you should look at 2000-2003 bikes.
Thanks for the help guys!
This is what I found, in case someone else does anything like this and needs the number:
The Pulley (70 tooth, 1-1/2 inch wide) is HD part number 40217-00. 2000-03 FLH/FLT
I've already got the rotor. I want to stick with the 1-1/2 inch belt since I have tendency to get a little frisky and do burnouts once in a while, probably moreso after Scott at Hillside does his magic on the heads
Definitely something for me to think about, what's the widest tire I can put on a 3 inch wide rear wheel? 150?
