Outer Primary Case Sealing Tips Please
1998 FLSTF
I have a primary case leak between the outer and inner primary case at the bottom rear bolt area. I have some Loctite 518 and Loctite 7649 Primer but I'm wondering, should I apply to both sides to be bonded, or just one side, and should I even get a gasket and apply to both sides or single side of that, or what would you suggest.
1998 FLSTF
Received 4,317 Likes
Would you guys suggest this then:
http://www.cometic.com/i-24866500-ha...ry-gasket.html
Instead of the 518 or in addition. I'm figuring without the 518 but just wanted to make sure.
Loctite 518 is a anaerobic sealer gasket material, supposed to be good stuff but I have never tried it before.
https://www.amazon.com/Loctite-50ml-.../dp/B000FONONG
Also, just saw this gasket on eBay
http://www.ebay.com/itm/HARLEY-DAVID...NS1qoJ&vxp=mtr
You won't need it and it will probably cause the foam to tear off the gasket when you remove it.
The only place you want to use a sealer is between the case halves.
Don't use it anywhere else on your bike!!!!!
That is the same gasket and yes that is what I use on my bike.
