1989 Turn Signal Problem
I have a 1989 FLHTC, for years if I turn on either the right or left turn signal occasionally they will not self cancel so I have to hit the button again to cancel them. Again this has been only on occasion and most of the time they worked OK.
Now the turn signals are not working at most of the time. If I hold in the right or left turn signal button, on the handlebar, I get nothing and the light bulb doe's not light up at all. Only on occasion I will get them to work. Sometimes only one blink to 5 blinks then nothing. Same with the four way hazard flasher.
I looked at the wiring diagram and listed is a directional flasher, a hazard flasher, a hazard flasher switch, and of course there is the self cancelling unit. Since for years occasionally the self cancelling did not work that self cancelling modular may be the problem. But would the self cancelling modular cause the light bulb not to light at all as I press on the handlebar switch?
I hope someone can point me in the right direction or have any test procedures to test each individual component.
Of course the flasher is cheep so I will try that first. Plus I will have to check with the dealer to see if they still support the self cancelling modular.
Thanks
Thanks
If finances allow....dont mess about buy the new Badlands. I am sure you wont regret it and the peace of mind is priceless.
If finances allow....dont mess about, buy the new Badlands. I am sure you wont regret it and the peace of mind is priceless.
troglodyte
10-03-2005 12:55 PM
