EVO - Miles on Reserve
Buy a Pingle and all your problems will disappear......
Besides the petcock..their are other factors that can affect reserve. Early Softail tanks had the petcock between the cylinders...which put it towards the front of the tank...if you lower one of these bikes in the rear...you can trap 3/4 gal or more...that you cannot get out regardless of the petcock you run. At some point they moved the petcock to the rear of the tank..where it should have been to start with...Food for thought.
JesseDyna (01-18-2017)
The best test is to keep track of your mileage and run it until it stalls. Put it in reserve and run it until it dies. Check milage.
Oh, carry a gallon to get you going and get to a gas station.
This is the only sure way you can answer your own question.
You're in Cali, there should be a station on every corner.
Received 4,317 Likes
I get between 30 and 40 miles out of mine and that's after I cut it 1/2"ish shorter.
I always win by a gallon on the "how much fuel did you use" when running hard with good running bikes
Received 5,388 Likes
