EVO - Miles on Reserve
8 miles hardly qualifies for being called a 'reserve'! I haven't attempted to dismantle my Pingel, but is it possible to add a longer tube, to increase reserve?
I have a 92 Softail. I have not tested the reserve, but I am assuming I would get 30 to 35 miles out of it. This is based on the gas mileage I get and the fact that I get about 3.5 gallons from the main and I believe the total capacity is 4.5 gallons.
I have never gone more than 5 miles on the reserve. I would like to know without finding out the hard way. Maybe I should ride it around the block until it runs out so I do not have to walk to far to go get gas.
Check fuel capacity on-line here, as some Softails have a 5 gallon tank
Received 4,317 Likes
Petcock
I also have a Pingle on mine, almost exactly the same amount of reserve too. Next time I have to drain the tank gonna cut it down like you did. How much did you cut off? Now If I can only get the damn fuel gauge to read correctly. I have an early Road King tank on mine and the gauge has never read full, even when I fill the tank right into the neck.
Besides the petcock..their are other factors that can affect reserve. Early Softail tanks had the petcock between the cylinders...which put it towards the front of the tank...if you lower one of these bikes in the rear...you can trap 3/4 gal or more...that you cannot get out regardless of the petcock you run. At some point they moved the petcock to the rear of the tank..where it should have been to start with...Food for thought.
I'ts been a while so I don't recall for sure.
