Softail Wiring Question
So I was looking at the factory manual, and then at the PDF manual I have as well, and they show this same setup for the main circuit. It doesn't seem right, so I'm hoping someone can shed some light here.
In the photo below, I feel like there should be a lead going from the battery (or the constant hot post of the solenoid) to the "input" side of the main circuit breaker (the same post that the output from the voltage regulator connects to).
Otherwise, how does the starter relay get power when the bike is not running - i.e. to operate the starter?
I'm at work and can't check for certain, but I'm pretty sure my bike has TWO wires connected to the "hot" leg of the main breaker. One comes from the voltage regulator, and one comes from the battery via the positive lug on the starter solenoid.
This would have to be or else there would be no power to the starter relay, ignition or anything else, and the alternator would not be able to charge the battery.
I looked at all the wiring diagrams in this manual and the only diagram that doesn't show a 'buss bar' from the battery to the main circuit breaker is the diagram for the 1984 FXST. I guess it could be a mistake that it was omitted in the diagram. I included a diagram from another model just for illustration purposes.
OP: Tell us the model and year of the bike in question...
I just noticed in one of my old early Softail FSM wiring diagrams that the copper strip that connects the battery positive post to the main breaker is not shown, just like the pic posted by OP.
The electricity must get to the main breaker by magic...
That PDF wiring diagram is garbage...
