Ignition Coil Wiring
Old 02-19-2017, 09:35 PM
sgr60's Avatar
sgr60
sgr60 is offline
Default Ignition Coil Wiring
I'm working on getting my ignition coil wired up on my 84 FXST, and I want to confirm the wiring.
From the harness that connects to the ignition module, there are two wires that run up to the coil - one is pink and the other is white. From what I understand, the pink wire is the ground to the coil (which causes it to fire) and the white is the + for the module itself.
Per the wiring diagrams I've found, these wires connect to each of the posts on the coil - with the white wire tying into the white positive wire that comes down from the kill switch on the handlebars, supplying power to both the coil and to the ignition module.
My question - does it matter which post on the coil the two white wires go to (together) and the pink wire? The posts are not labeled, that's why I ask...
Here's what my coil looks like:
Old 02-20-2017, 08:51 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,681 Likes on 1,338 Posts
The pink wire is your tach wire. The two white wires should go on the upper connection and the pink wire and a blue wire from the module go to the bottom connection, if it has a factory ignition module. The blue wire is what grounds the coil and ungrounds it to fire.
Old 02-20-2017, 09:01 AM
sgr60's Avatar
sgr60
sgr60 is offline
I don't have a blue wire coming from my module - but all the others seems to be accounted for, so that's why I thought the pink wire was the ground to the coil.
Here's what I'm working with:
Old 02-20-2017, 10:03 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
You should have 7 wires coming from the module:
Red, Black, Green go to the pickup in the cone.
White to the top of the coil.
Blue to the bottom of the coil with the pink wire from the tach.
A wire, probably violet, going to the VOES.
A short black wire with a ring on it going to ground, probably at the module mounting bolt. Note that this wire is not in the harness/connection.
It won't fire without that blue wire.
Old 02-20-2017, 01:27 PM
sgr60's Avatar
sgr60
sgr60 is offline
It's got 7 wires, just not a blue one.
red, green, black strip to cone
purple voes
black ground
whte and pink to coil
Is it possible that the pink wire is in place of the blue one and there is no tach wire? How could I test that?
Im at a loss because the blue wire just isn't there...
Old 02-20-2017, 01:40 PM
IBDAGRIZ's Avatar
IBDAGRIZ
IBDAGRIZ is offline
On a 7 pin module I show.
#1. White-ign power
#2 Black/white tracer-Pickup sensor ground
#3 Red-Pickup sensor power
#4 Pink- Coil (-)
$5 Green- Pickup sensor signal
#6 Purple- VOES
#7 Black- Ign ground
Hope that helps..
Griz
bentpartsoutlet (10-26-2020)
Old 02-20-2017, 02:20 PM
sgr60's Avatar
sgr60
sgr60 is offline
Thanks Griz - that's exactly how mine is setup, so I think I should be all set. I hope...
Old 02-20-2017, 02:29 PM
IBDAGRIZ's Avatar
IBDAGRIZ
IBDAGRIZ is offline
Just don't let the smoke out of the wiring.
Griz
Old 02-20-2017, 02:38 PM
sgr60's Avatar
sgr60
sgr60 is offline
The smoke?
I just wonder why that wire is pink rather than blue...
Old 02-20-2017, 05:45 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Is there a tach on the bike? As long as one of the wires from the module goes to the coil negative side, it should work. If all the other wires are accounted for, then pink it is.
Quick Reply: Ignition Coil Wiring
