96 Fatboy caliper upgrade advice
I don't see why you couldn't use whatever dot you choose. Somebody would need to explain that to me, really well and in small words so I could understand.
My only concern would be contamination of two different ratings of brake fluid. I would clean them both and do a m/c rebuild to boot just to make me comfy.
Triple trees for an FL softie are narrower than a bagger. This I am sure of. Unless you machine some width off of the wheel hub then a dual disc will not fit easily into a fat boy . Part numbers for light bars are different as well from bagger to FL softail.
Good luck,
Tom
Good luck,
Tom
Received 4,317 Likes
Good luck,
Tom
Good luck,
Tom
What is that little bracket? Or who makes it?
I am running this caliper and bracket combo on my Twin Cam with the stock 9/16" master cylinder with no issues. I am currently in the works of installing a very similar Brembo and bracket on my Evo. Like the Twin Cam I will be using the stock 5/8" master cylinder. Both bikes are using Magnum Shielding Sterling Chromite II brake lines and Motul RBF600 DOT 4 brake fluid. Below is a pic of the Twin Cam, I'll try to get one of the Evo soon...
