Dead coil after 8 miles
Received 4,317 Likes
I will but it might take a while as I've started my famous "since I'm there" mode.
In other words I start replacing things that look a bit worn or damaged.
For example I'm replacing the battery cables and the rear brake mounting pins to name a couple.
0maha (04-21-2017)
Update:
Just put the new wiring harness on and new battery cables on the '94.
I turned on the ignition to check to make sure that everything worked and low and behold the left turn signal didn't work!!!!!!!
Well a lot of cussing and a little looking and I found where they left a 2 pin bridge off the first connector of the wiring harness!!!!
I grabbed one off the old harness and installed it and the left turn signal works!!!!!!!
Well reassembly continues....
