Battery blew up on me yesterday
Old 04-10-2017, 08:01 AM
Doug Fogleman's Avatar
Doug Fogleman
Doug Fogleman is offline
Default Battery blew up on me yesterday
So I was riding, smelled something....Off.... Move to pull over, and BOOM. no power. Smokes pouring out between my legs. The whole bit.
now I'm no professional, but does anybody have an idea, where I should start to check, as to the cause.
I'm thinking regulator,
Old 04-13-2017, 09:44 PM
jammerx's Avatar
jammerx
jammerx is offline
wow....
Old 04-13-2017, 09:46 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Just pulled mine Sunday. It started no problem.
Moco battery from 2007!!!!!!!!!!!!!!!!!
Why buy something else?!?!?!?!
Old 04-13-2017, 10:19 PM
103 sedona orange's Avatar
103 sedona orange
103 sedona orange is offline
WTH! He's not asking about what battery to buy, he's wants to know what caused his battery to explode.
Old 04-13-2017, 10:25 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,775 Likes on 17,441 Posts
Dead short on a big cable or the internal plates collapsed, seen a few pop the sides & top off but yours is a first melted out like that.
Old 04-13-2017, 10:43 PM
Ron750's Avatar
Ron750
Ron750 is offline
Received 16,512 Likes on 6,270 Posts
He is saying Harley Batteries don't explode. I stick with the East Penn battery, same as the Harley. Sold as Duracell at Batteries Plus.
I like the collapsing plate theory. OP, what brand was the battery? As soon as you saw the made in China part of your battery you should have stayed away.
joe40x (06-04-2019)
Old 04-14-2017, 07:00 AM
KozmoSoftail98's Avatar
KozmoSoftail98
KozmoSoftail98 is offline
Did this post get deleted and reposted? Voltage Regulator. Mine died and when that happens voltage to the battery is about 18 volts. It is a bad situation and I would like to know how to get a warning when the regulator takes a puke. Mine hadn't melted yet but was smoking and bulging.
Old 04-14-2017, 07:10 AM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,726 Likes on 924 Posts
Install a voltage meter/gauge? A simple solution for over voltage would be a red LED installed with a resistor so it would only illuminate when the voltage gets to say 15 or 16 volts. Never tried it but just a thought. YD
http://led.linear1.org/1led.wiz
Old 04-14-2017, 08:12 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,467 Likes on 4,598 Posts
Any battery that has wet cells can explode, no matter whose name is on it.
Make sure all connections are secure on the new battery cables, and once running check the charging system to make sure it is working correctly.
Don`t use a Chinese battery.
Old 04-15-2017, 05:56 AM
KozmoSoftail98
Yankee Dog: I agree and think the only way to know when the Voltage Regulator has died would be a meter/gauge mounted on the handlebars, or somewhere. I was definitely rattled when I pulled in my driveway and had sulfuric smoke coming from under the seat.
Quick Reply: Battery blew up on me yesterday
