Lifter swap advive
Old 04-20-2017, 07:08 AM
flhchaz's Avatar
flhchaz
flhchaz is offline
Received 1,285 Likes on 499 Posts
Default Lifter swap advive
Hey all. I am changing out the lifters on my '97 Electra Glide. I currently have adjustable pushrods and am replacing them with the stock pushrods, the threads on the adjustables have a bad spot in them (another reason to do your own wrenching).
Should I use the alignment tools for the lifter blocks?
Do I need to have the piston at the top of it's travel to put everything back together?
In the chevy small blocks that I have built, I've always soaked the the lifters in oil for a day, should I also soak these lifters in oil?
I've done a lot of work on my bikes, but never got into the motor. any advice will be welcome
Old 04-20-2017, 07:18 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,803 Likes on 3,311 Posts
So i take it your taking the heads off... Not a bad idea to soak them but not necessary. No you really don't need the alignment tool for the lifter blocks, the bolts have little slop. And keeping the front on tdc is usually the way to go so you know where you're at.. remember that the oem pushrods are different lengths and have a specific position. front, rear and intake or exhaust.
Old 04-20-2017, 07:26 AM
flhchaz's Avatar
flhchaz
flhchaz is offline
Thanks for the info. I wasn't planing to take the heads off, just the rocker boxes. The stock pushrods are color coded, I remember a certain saying that I learned on the forums to remember the color order from beemervet.
Old 04-20-2017, 07:33 AM
0maha's Avatar
0maha
0maha is offline
Received 4,667 Likes on 1,660 Posts
I was impressed by Kenny Tatro's take on the lifter block alignment tools: "Who says the holes in the case are in the right place?"
Makes sense to me.
Hackd (04-20-2017)
Old 04-20-2017, 08:04 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,494 Likes on 4,611 Posts
Pushrod Locations:
Longest, front exhaust
Second longest, rear exhaust
Third longest, front intake
The best way to assemble the top end using the oem pushrods is to follow the service manual religously in this area, to avoid bending a valve or pushrod.
Makes sense to me.
Have you heard of any cam lobe damage or lifter roller damage due to the holes being in the wrong place? It`s the same tool as an oil pump alignment tool, the service manual recommends using it, so why not?
I`m not impressed by how tatro tosses his customers parts around on the disorganized workbench, in his disorganized shop.
Old 04-20-2017, 08:10 AM
Hackd's Avatar
Hackd
Hackd is offline
Old 04-20-2017, 08:24 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,703 Likes on 1,988 Posts
Makes sense to me.
If they're not, now do you propose to align the lifter blocks? Honestly, the things some people go through to avoid buying a $10 tool sometimes amaze me.
Old 04-20-2017, 08:35 AM
flhchaz's Avatar
flhchaz
flhchaz is offline
I'm not against buying the tool. I have a drawer full of tool that I've used once. It just seems odd to me that there are 4 bolts that hold it in place, what's to align? Again, I've never done this before.
Old 04-20-2017, 08:42 AM
Hackd's Avatar
Hackd
Hackd is offline
I'm a charter member of that club... Last frivolous purchase was a JIMS tool to install exhaust gaskets. And it was a lot more than $10...
Oh... Forgot: Last night, I just ordered 1/2" and 3/8" drive 12 point deep well sockets on Amazon.
I need a 12 step program....
Old 04-20-2017, 08:43 AM
br549A1's Avatar
br549A1
br549A1 is offline
I'm pretty sure I have two alignment pins at home. If you want one it's yours, I have to look when I get home to make sure I still have it. I only need one in the tool box. Let me know
Quick Reply: Lifter swap advive
