OK guys and gals, replaced exhaust gaskets to no avail. Avail means, no success.
Im sure its probably some small over looked something.
I am taking bids on this engine to absorb the cost of the new V111. Any takers?
You want a bid on a motor that doesn't run right and has a history of putting metal flakes into the oil????
I'll go $6. Am I reading this right do you have two good ignition set ups? If you want to sell one PM me I might be able to cancel my order on the new one still.
Rechecked my new intake seals for leaking, yep they are leaking. Idling problem most likely solved. I remembered today when I first installed the intake 4 years ago it had a small ripple bend on the edge of "back cyl". I'm ordering a new intake Monday. That's got to be it, I rebuilt everything else.
The ultima adj ignition I took out is good, I will let you have it. You will need a 3 ohm coil to run with it. Either single or duel fire.
Id like to keep my other Dynatek coil.
