Leak Down Question
Old 04-25-2017, 08:28 PM
Tony_N's Avatar
Tony_N
Tony_N is offline
Originally Posted by aces&8s
Great, I figured out what was wrong.
What was wrong?
Old 04-26-2017, 06:18 AM
flhchaz's Avatar
flhchaz
flhchaz is offline
Received 1,285 Likes on 499 Posts
Originally Posted by Tony_N
What was wrong?
Old 04-26-2017, 07:36 AM
WP50's Avatar
WP50
WP50 is online now
Received 1,698 Likes on 1,153 Posts
Dang Dude You have been around long enough to know better than to leave it at that "Great, I figured out what was wrong."
What was it
WP
Old 04-26-2017, 09:02 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,810 Likes on 3,315 Posts
Was your motor setup to 208 CCP? Cause after 25k on the build I would think that carbon is building......
I'm thinking he found a bad plug wire.......
Old 04-26-2017, 11:19 AM
KozmoSoftail98's Avatar
KozmoSoftail98
KozmoSoftail98 is offline
Please, complete the thread with how you fixed it. We would like to know. Thanks
Old 04-26-2017, 11:44 AM
aces&8s's Avatar
aces&8s
aces&8s is offline
My engine had 200+ compression when built. 10-1 weiscos, shaved heads, .030 cometics HG.
I already changed plugs and wires as stated earlier. Got to go back to work right now.
Old 04-26-2017, 04:15 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
Back home from work and went for a ride and as the engine warmed up the problem came back. The new ignition and coil did not fix it. Anyone have an idea?
Old 04-26-2017, 04:21 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
As engine warm up, Miss fire at idle and rear exhaust makes a fluff sound and wont idle.
Spark plugs are perfect color and I also changed them and the wires.
Yes, no intake leaks with carb cleaner.
Its S&S carb and I dropped the bowl and pulled the jets, all is well.
new Ignition & coil is installed.
Regulator is good.
Old 04-26-2017, 04:27 PM
flhchaz's Avatar
flhchaz
flhchaz is offline
aces&8s (04-26-2017)
Old 04-26-2017, 05:56 PM
98hotrodfatboy
Sorry missed the wires change....
Have you checked the ignition rotor on the cam to see if maybe it loosened up a little.
What about the cam sensor, any goo leaking out?
Quick Reply: Leak Down Question
